what make same Uv detector different ?
Posted: Tue Mar 29, 2011 3:04 pm
Hi there ,
I read a lot by googling about detector but i am sure i will find here distinction answer .Now i use one detector called ( UV-VIS ) and my friend and others use the same ( UV-VIS ) but each one use it from different company . The question is :
when I rum my standard the ( peak in height and Area ) are different one are small and other is big etc .
which factor control this and make detector different from each other ?
I am really need this information so please be " good lover " and help me
New
New
