ISOBARIC PEAKS
Posted: Tue Mar 29, 2011 12:51 am
Would anyone be able to tell me the best way to approach seperating Isobaric Peaks ( hydroxy estrogens and methoxy estrogens) using LC-MS/MS i.e, LC Gradient elusion. I'm not able to get good resolution of these ISOBARIC peaks.
hydroxy estrogens: 2-hydroxy and 4-hydroxy estrogens
2-hydroxy and 4-hydroxy estradiol (2-OHE2 and 4-OHE2) : 755/521
2-hydroxy and 4-hydroxy estrone (2-OHE1 and 4-OHE1): 753/170
methoxy estrogens: 2-methoxy and 4-methoxy estrogens
2-MeOE2 and 4-MeOE2 : 536/171
2-MeOE1 and 4-MeOE1 : 534/171
Internal Standard: Ethinyl Estradiol (EE2) : 530/171
Dansyl chloride derivatization
Mobile Phase; Water with 0.1% FA (A) and
ACN with 0.1% FA (B)
GRADIENT: Time Flow %B
0.00 500 uL/min 00.00
10.00 500 40.00
12.00 500 65.00
18.00 500 55.00
22.00 500 40.00
22.50 500 00.00
25.00 500 00.00
RP C18 Column: 25 cm x 4.6 mm, 5 um
Flow rate : 500 uL/min ; Total run time is 25 min.
Injection volume : 10 uL
MS: ESI- Positive Ion Mode
Please suggest me a good resolution method.
With regards
RajaSekar
10.00 500 40.00
12.00 500 65.00
18.00 500 55.00
22.00 500 40.00
22.50 500 00.00
25.00 500 00.00
With regards
RajaSekar
