Determining the isocratic void using a short column
Posted: Fri Mar 25, 2011 1:18 am
I have a problem compound that I can only get good chromatography for using this scenario:
20/80 H2O/ACN
Thermo Scientific Hypersil Gold, 2.1 x 50mm, 1.9ยต
0.600mL/min flow rate
Retention time is 0.17 minutes
Total Run time is 3.0 minutes
I know this is very early, and I use gradient methods 99% of the time, but the peak shape is nice and the experiment passes. What would be an acceptable retention time in this case? Is any retention time acceptable when using isocratic?
20/80 H2O/ACN
