how do I got a good IC column?
Posted: Tue Mar 22, 2011 12:25 pm
by wsj365
I have used anion column such as ALLSEP and SHODEX,but it only use several weeks.what column did you use?how about life-span?
Re: how do I got a good IC column?
Posted: Tue Mar 22, 2011 7:29 pm
by JGK
Nobody can answer your question without more information. For example I know columns can last for decades if you leave them sealed up in the box.
In your case, in order to be able to answer your question we need to know what are the chromatographic conditions you are using and what type of samples you are injecting?
Posted: Wed Mar 23, 2011 7:26 am
by Markus Laeubli, Metrohm
Dear wsj365
One is able to kill any column with certain samples almost immediately. Therefore column lifetime is not only a question of the manufacturer but also of the user and its samples and sample preparation.
Posted: Wed Mar 30, 2011 2:57 pm
by wsj365
thanks for your reply.the chromatographic conditions has been according to the instruction of the column absolutely.the life-span is so shot because of the limited of the column capacity.I am in china and could you supply the column for me ?
my e-mail :wangshujie365@yahoo.com.cn
