GC-IRMS problem
Posted: Mon Mar 21, 2011 2:25 am
I am using a delta xp GC-IRMS , the initial 20 samples ran well with consistant results. I am now getting -10 per mil increase in value from the same samples. I have checked for any leakage with Argon and checking for any peaks coming off on mass of 40 after a minute or more. there look to be no problem, except water background increased by 6 volts and peaks that were prviously showing at 3 volts are now appearing to be 1 volts. I wonder if any one could help me throughthis.
