VCR fittings
Posted: Sat Mar 19, 2011 4:01 am
by thohry
Dear all,
In a GC system, the manual requires that VCR fittings must be used. I understand that it must be clean and tight, but do not know what VCR stands for. Anyone know that?
Thanks.
Re: VCR fittings
Posted: Sat Mar 19, 2011 3:07 pm
by tom jupille
I have no idea what "VCR" stands for, but here's what they are:
http://www.swagelok.com/products/fittin ... bAodtBUU_A
Maybe contact Swagelok and ask if anyone there knows where that particular TLA came from.
("TLA" is a three-letter-acronym for "Three Letter Acronym")
Re: VCR fittings
Posted: Sat Mar 19, 2011 5:49 pm
by chromatographer1
Variable Compression Ratio fittings are used when a connection of two pipes or tubes receive thermal changes in use. Metal compression fittings (Swagelok) usually are not replaceable if they leak but the tube must be trimmed and a new fitting installed.
The VCR fitting uses a replaceable metal gasket to seal between two pipe or tube ends, no rubber or plastic seal is used, even to seal heated vapors. VCR is a trademark of the Swagelok company.
I hope this is helpful.
Re: VCR fittings
Posted: Sun Mar 20, 2011 4:21 pm
by thohry
Thank you very much !
