Determine VLE of acetonitrile-toluene with SHS-GC
Posted: Wed Mar 09, 2011 10:51 am
I'm a student studying vapor liquid equilibria of different mixtures with static headspace gas chromatography. Now I'm working with the mixture of acetonitrile-toluene. In order to check my results I need to compare them with literature data.
I analysed different molar fractions of acetonitrile-toluene from 0.1-0.9 of acetonitrile, respectively toluene. I used a sample volume of 5ml in the vial. And thermostated at 70 °C (because they also used this temperature in literature) during 15 min (I already checked whether the equilibrium was reached and indeed it was). Then the detection happend with a FID.
In order to set up a Y-X diagram of acetonitrile and toluene. Since I've made the solution I know the molar fraction in liquid phase (X). But I have some problems to determine the molar fraction in vapor phase (Y). In the chromatogram I have 2 peak areas (from acetonitrile and toluene). If I need to calculate to molar fraction of 1 compound in vapor fase, is it scientifically correct to only use the peak areas ?
For example: component A : peak area 10 000, component B peak area 20000
Then the Y for compent A is: 10 000/(10 000+20 000)= 0.33 ?
Because if I do this my experimental data does not match the literature data. But what I do notice is that if I add a constant value of 0.22 to each molar fraction in vapor fase, the experimental data does match the literature data (but I don't have any explanation for that, so I can't do this).
Now I was wondering if sombody is seeing something that I am forgotten or did wrong. I also found different things concerning activity coefficiënts and response factor but I don't seem to find anything to associate it with the peak area.
I hope someone can help me.
Regards
Nick
Regards
Nick
