recommend a filter to filter out the propylene glycol
Posted: Fri Mar 04, 2011 3:29 am
We have a very low dose fomulation that uses ethanol:propylene glycol:H2O=5:45:50 as vehicle and hope to directly inject this formulation into HPLC without diluting. Although I am worried about the viscosity of the Propylene glycol the pressure looks OK while shooting it directly into HPLC, I've tried filtering samples (0.45um nylon, PTFE, GHP) before injection but all have interference peaks, so can I not filter the sample because the pressure didn't seem to increase at all?
Thanks.
Thanks.
