FAME analysis on BPX70 - Odd Chromatograms
Posted: Tue Mar 01, 2011 10:04 am
Hi All,
I am looking for some ideas to help fix a problem I'm experiencing analysing FAME on a BPX70 column (Clarus500 GC). It has been noticed that during a sequence there is a random error in which the chromatography of a smaple deteriorates so instead of nice sharp peaks, they become broad and short. This problem continues until until the peaks become broader and broader until a flat baseline is observed (with the exception of the solvent peak which remains unchanged).
Baking the column tends to remedy this but i am trying to find the underlying problem that is causing this nuisance.
No changes have been made to the instrument set up apart from routine maintenance (ie septa and liner changes) but there appears to be no connection as to when the maintenance is performed and the porr chromatography is observed.
Any thoughts would be welcome.
Steve
Steve
