Relation between column length and flow rate
Posted: Wed Feb 23, 2011 8:11 pm
I know that by changing column dimensions, we have to adjust flow rate to maintain the retention time.
However, this might sound a little silly, but wanted to know if there is any relationship between column length and flow rate too.
example,
If my 1st column is 4.6 x 50mm x 5um with flow rate of 2ml/min and then 2nd column I choose will be - 2.5 x 100mm x 3um --> how will the longer column effect the flow rate that I should use?
Sorry if this has been asked before, but I searched and din't find anything very specific
example,
