column life time is very short
Posted: Wed Feb 23, 2011 6:10 am
Hello everyone! I have developed a method to quantify Ambroxol HCl, dextromethorphan HBr and sodium benzoate in a syrup as following:
mobile phase: sodium 1- heptanesulfonate 0.005 M and buffered (phosphates) at pH= 2.8. (A)
acetonitrile (b)
There is agradient that goes from (80:20) (A:B) to 70:30 and later returns to 80:20.
column: 4.6 x 150 mm C18 Symmetry 3.5 micrometers
The standards and samples are disolved with mobile phase.
I obtain the three peaks correspondigs to my analytes, but later of around 70 injections the peaks don't present a gaussian form and look like rectangles. I have put through the column water:acetonitile after each batch sample and regenerated the column with dimethyl sulfoxide but i cant come back to my original chromatogram. The pressure in the column is similar to the beginning of its use.
The column has not been used with a different mobile phase.
The retention times are not changing.
What can I do to extend the life time of my next columns and prevent this situation?
please feel free to make any kind of suggestions to the entire method.
Isaac
acetonitrile (b)
Isaac
