Fast GC with TCD detector and capilary columns?
Posted: Mon Feb 14, 2011 3:42 pm
Dear all,
I have a Perkin Elmer Clarus 500 GC/TCD with packed columns (pora pack q and molsieve 5A) for separation of CO, CO2, N2, O2, CH4, C2H4 and C2H6. However because of the packed columns I can not reduce the analysis time below 15 minutes.
I have read few examples of a micro GC applications, among which I have seen that a combination of 5-10 meters of capilary columns (0.32 mm) poraPlot Q and Molsieve 5A can separate this mixture isothermally in less than 5 minutes. However, I am not sure if my TCD detector can be used in case of a small flows and even smaller amounts injected into the column. I need to determine all the mentioned species quantitatively untill a lower limit of 500 ppm.
I would realy apreciate any comments or advices!
