GC analysis of phthaloyl Chloride
Posted: Sun Feb 13, 2011 4:33 pm
by praveenpaliwal
Hellow every body
I need immediate help form all of u. I got this compound and derivatize it with 2M THF solution of Dimethyl amine I got sharp peak. I alos found separate peak of phthalic anahydride but before this peak I found a hump which could not remove. I want know what is other possibility to analyze this compound and find the phthalic anahydride separately.
Praveen
Re: GC analysis of phthaloyl Chloride
Posted: Sat Mar 05, 2011 4:14 pm
by praveenpaliwal
I still not found any reply. I also analyze this compound as such with MDC , The compound shows two peaks, our supplier also provide us the 30 % solution with MDC and 100% polysiloxane phase but i am not satisfied,because phthalic anahydride is not dissolve in MDC so the amount which I got on analysis is not correct. I need some suggestion for this compound.
Best regards
Praveen
Posted: Sun Mar 06, 2011 2:04 am
by Don_Hilton
If I understand, you have reacted phthalolyl chloride with dimethyamine - which would be expecte to give the diamide. You have three peaks in the chromatogram - one the diamide, the second phthalic anahydride, and the third is something you have tried to remove. You want to analyze this compound - and I am not sure if you refer to the compund you can not remove or the phthaloyl chloride. And you want a separate assay for phthaloyl anhydride?
You tried to remove this other compund/peak by changes in chromatographic condition or by changes in sample handling?
Tell us what the objective of the analysis is and what analytical range is of interest.
You describe that you analyze this compund "as such with MDC" - Is this that you disolve the phthaloyl chloride in MDC (I assume dichloromethane?) and inject it in the GC without derivitization? And how do the two peaks relate to the peaks you described in the first posting? How does t his relate to the 30% solution in MDC from the supplier? And is the 100% siloxane phase your GC column or something else?
Give the details - how much sample are you using, what solvents, what quantity of reagent, what precautions are taken to be sure everything is anhydrous?
