Help with clean up SPE
Posted: Tue Feb 08, 2011 10:07 pm
Dear All,
I'm trying to validate a technique to measure the metabolite of vitamin D3, 25(OH)D3, using published methodology by Kand'ar and Zakova (2009) with some differences between brands of column and SPE resin C18. The authors used Discovery DSC-18 SPE tube with a bed weight of 500 mg and a column volume of 3 mL. I'm using an in house made SPE tube with Sepra C18-E (50 um, 65A) - bed weight of 500 mg and vol. of 3 mL.
The procedure is as follows:
The column washed with methanol (2 mL)
The column equilibrated with ethanol–water (1:3 v/v) (2x2 mL)
Diluted supernatant applied to the column (Discard effluent)
The column washed with water (2x2 mL) (Discard effluents)
The column washed with methanol –water (2:3 v/v) (2x2 mL) (Discard effluents)
25(OH)D3 eluted with 100% methanol (2x200 uL)
Actually, I'm working with standards.
I can't see any growing peak in the chromatograms. Around 3 minutes, detection falls bellow the baseline.
well, I don't know what may be happening! I appreciate any help.
Guilherme
Guilherme
