a formulation question-how to use Palmitic acid as excipient
Posted: Sun Feb 06, 2011 4:58 pm
Dear all:
Now I am trying to use Palmitic acid as an excipient vehicle for my API (vitamin D5) and fill in the soft gel capsule.
The palmetic acid came as solid, since the melting point is around 50 degree, shall I warm it at 50 degree oven to transfer it to liquid and then add API? Or shall I mix the palmitic acid with some other excipient because I am not sure if it will trun back into solid stage after sitting at room temperature. If yes what other excipient is compatible with palmitic acid? I am not a formulator so I am quite confused.
Thanks.
Thanks.
