Difference between correlation coefficient and COD
Posted: Sun Feb 06, 2011 6:21 am
Is it correct to say that correlation coefficient (r) can denote the goodness of fit only when there is no weighting factor used in the linear regression line? If a weighting factor is used, only coefficient of determination (r2) is used instead to denote the goodness of fit. And coefficient of determination can be used in both situations!?
Are there any other differences?
Thanks.
Thanks.
