ELSD Calculations
Posted: Wed Feb 02, 2011 9:37 pm
I am developing a method for determining the amidoamine (CAPA) present in cocoamidopropyl betaine (CAPB) via HPLC, using an ELSD detector, which does not yield linear results. However, I was able to obtain a calibration curve using the power curve function in ChemStation. When running unknown samples the software calculates the ppm based off the calibration curve. How do I take my sample weights and or dilutions of the unknowns in consideration when calculating the final concentration of the unknown? Or is the value that chemstation is calculating the true and accurate value based off area? When entering sample information prior to injection, it does allow me to enter sample weights and dilution, however it states that the sample weights are not used in reported calculation. After the result is given in (PPM) would I multiply by vol (mL) and divide by mass (g) to obtain a final final value or can this only be used if using linear calculations? Any assistance in regards to this matter will be greatly appreciated. Thanks in advance for your cooperation =)!
