SPME, organochlorine pesticide, ISTD
Posted: Fri Jan 28, 2011 6:01 am
Dear all,
I am a newbie in SPME and GC/MS and have no strong background in chemical.
I would like to analyze organochlorine pesticide in water samples. I am using OCPs mix standard and pentachloronitrobenzene (PNCB) as internal standard.
As starting to check the methods according to papers and analyze spike samples which have concentration
• 80 µL of OCP mix standard with 50 ng/ml + 40 µL pentachloronitrobenzene 100ng/ml in miliQ water until the total volume 4ml. all standard I made it in acetone. volume of acetone was ≤3% of Volume total, please correct me.
• I used 30µm PDMS fiber ,immersion time 15min, agitation, no NaCl in room temperature
• I use GC 17C and QP 5050A Shimadzu with coloumn Rtx 30 m x 0.25mm I.D 0.25µ
• Operational condition, Interface 270°C, Injection 250 °C, Gas flow 1 /min, Splitless ratio 50:1, SIM mode, Open valve 2 min
PCNB peak was sharp but there were no peak of OCPs standard at all. Did my procedure was wrong, or the equipment was not enough? Did I choose wrong internal standard? Please give me suggestion because I am running out the time.
Thank you in advance and I am sorry for my poor English.
pipie
pipie
