analysis of benzoyl peroxide gel
Posted: Thu Jan 27, 2011 11:02 pm
Hi, Im having trouble with the analysis of benzoyl peroxide gel containing an antibiotic (which is run on a separate method).
The solvent is acetonitrile water.
The method is run at low pH and is gradient.
Wavelength is 254 nm
The benzoyl peroxide degrades to form benzoic acid quite quickly, and im wondering if there is an issue with sample stability.
Anyone faced similar problems, or have any ideas what could be wrong
Also does anyone know what the USP limit for benzoic acid in benzoyl peroxide gel is?
Tina
Tina
