Similar peaks for dsRNA and dsRNA-protein complexes
Discussions about gel permeation chromatography / gel filtration chromatography / size exclusion chromatography
I'm doing a size-exclusion chromatography and am trying to separate out the dsRNA-protein complexes from a solution that has free protein, free dsRNA and complexes. Although I can see a peak for the dsRNA alone after the dsRNA-protein complex peak, I want to know why (in relation to Beer's law) the peaks are similar, i.e, both peaks have a higher 260 absorbance than 280. For protein-only peaks, the 280 is higher than 260.
Most likely the peaks are not what you think they are. The Beer-Lambert law is innocent.
The peaks are what I think they are because we done other confirmation tests which proved it. However I do not understand why the peaks are similar for the protein-nucleic acid AND nucleic acid but diff from a protein only peak.
Most likely the confirmation tests are not what you think they are.
Proteins conformation (secondary, tertiary, and quaternary structure) has impact on absorbance. 280 nm is characteristic wavelength for aromatic rings in hydrophobic residues of proteins. Unfolding leads to an increase in absorbance. Is it possible that in your dsRNA-protein complexes hydrophobic residues are more shielded than in free protein?
Thanks Dorota, by electron microscopy we are not able to tell, however this may be a possibility. Thanks for the input!
In total there are 16 users online :: 0 registered, 0 hidden and 16 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 16 guests
