Splitting Peak for Pyridoxal Phosphate
Posted: Mon Jan 24, 2011 5:04 pm
I am using a Waters C18 column to quantify Pyridoxal 5' Phosphate in serum, with fluorescent detection at 418nm. Although I do get an ok separation, I find that the peak occasionally splits. When I prep samples in duplicate, this splitting (or shoulder) happens in both relicates; but, if I repeat the sample prep and re-run it, I often can obtain just the single (ideal) peak for PLP. I know it's a problem of splitting rather than contamination, because when i do get just the single peak for PLP, its area corresponds to the sum of the two split parts.
I have replaced the column and all reagents in the sample prep, and taken measures to keep air out of the system.
Has anyone else had this problem - could it be considered NOT a problem but an acceptable feature of the chromatogram?
