MOA for ACetic acid
Posted: Sun Jan 23, 2011 11:26 am
by vijayak
Can any one suggest MOA for Acetic acid and formic acid. I am already using a method using derivatization usinf p-toluene sulphonlic acid using DB-624.
Since because of regulatory issues i wanted to use with derivatization i tried injecting acetic acid and formic acid directly in DB-624 but poor peaks were observed and for formic acid response is too less in my FID.
Kindly suggest any method for acetic acid and formic acid using FID.
Regards
Vijayak
Re: MOA for ACetic acid
Posted: Mon Jan 24, 2011 2:37 am
by chromatographer1
You could use HPLC for the analysis.
You could use GC-TCD or helium ionization detector using a direct injection onto a FFAP/SP-1000 capillary. Note: acetic elutes before formic.
You could try esterification with isopropanol and sulfuric acid and use a porous polymer column to separate IPA from the esters of formic and acetic acids.
Without my books that is the best I can offer at this time.
Posted: Mon Jan 24, 2011 6:25 am
by kalidassa
Hai this is Kalidass find the below which we are analyzing formic acid and formaldehyde by derivation method, you can try for acetic Acid also
Simultaneous determination of formic acid and formaldehyde in pharmaceutical excipients using headspace GC/MS
Original Research Article
Journal of Pharmaceutical and Biomedical Analysis, Volume 41, Issue 3, 7 June 2006, Pages 738-743
Mary-Anne del Barrio, Jack Hu, Pengzu Zhou and Nina Cauchon
Best wishes
Regards
A.KALIDASS
Posted: Wed Jan 26, 2011 9:46 am
by vijayak
Thank you guys.
Vijayak
Posted: Wed Jan 26, 2011 2:10 pm
by Consumer Products Guy
OK, figured out that MOA meant "method of analysis", never heard that term in 35 years in the industry. Hate those %#$^&&##%^%@#&* TLAs.
