Saggy Agilent NCI Filaments
Posted: Sat Jan 15, 2011 6:16 pm
I am doing a GC/MS NCI analysis using PTV injection and an Agilent 5975 MS with ammonia as a CI gas. I am perplexed why some CI filaments last forever, and other filaments start sagging within a few weeks and require replacement in less than a month. You can see the difference when checking the tune -- the good filaments show a constant abundance and a bad (saggy) filaments are characterized by a decreasing abundance when checking the tune. (The filament must line up with the tiny hole in the source body). I asked Agilent tech support about this, and they didn't have an answer. There is no air leak -- I am using SF6 to check for leaks and the instrument is very-very sensitive to SF6 -- a leak will show up almost immediately, even if the SF6 source is 3-4 feet away from the instrument.
It is a real pleasure to get one of these "good" filaments. Wonder if anyone would hazard a guess, as to what is going on here?
