Cyclohexane pressure problems with Hitachi pump
Posted: Thu Feb 24, 2005 5:42 pm
Working with 100% cyclohexane and n-hexane (and only then), I have observed (ternary Hitachi L-6200 pump) that the pressure drop was severely fluctuating (e.g. from 0, 10, 12 bar minimum to 80 bar maximum, every few seconds), with the column. When the column was removed, I observed the same pressure variation (naturally, smaller range 0-7 bar) and flow rate variance as well (i.e. when pressure went down to 0 there was no flow while it was at 7 the flow was too fast, almost overflowing).
Interestingly - the problem immediately went away when I employed a different solvent (such as Methanol, Acetone, n-Propanol), either through the same line or another line in my ternary Hitachi L-6200 pump. The flow rate was set to 1 mL/min and only cyclohexane or hexane did not demonstrate constant flow rate (measured over 5 minutes) while the other solvents did well. It must be added here that the problem was permanent whether I was degassing them with He sparge (constantly, by the way) or not, even when the bottles were pressurized with He (10 psi).
At first, I thought the check valves were wrong (while cyclohexane was there) and, as a result, I practically, step-by-step, have rebuilt the whole pump: changed both check valves, piston seals and at the end I also changed the pistons to brand new ones. The result was… no improvement whatsoever! Still the fluctuation with these two solvents was very high and it was impossible to develop any gradient run with them (my setup was NPLC gradient from 100% Cyclohexane or Hexane to 100% n-Propanol or Acetone). Then I replaced them (the same solvent line A) with Methanol and … voila! The flow rate and pressure stabilized immediately. Also, when cyclohexane or hexane were mixed (during the gradient runs) with either of two other solvents (by the pump mixer) the problem went away (with higher %B content) and came back again upon column re-equilibration with 100% hexanes again.
Is this about compressibility only?
I will be grateful for any suggestions about practical solution to this problem.
Regards!
Maciej Turowski
Regards!
Maciej Turowski
