Macro - editing sample info...?
Posted: Fri Jan 14, 2011 5:27 pm
Using GC ChemStation - trying to find out if there is a macro-way to set up the datanaming in the Sample Info.
In a sequence mode, this can be done through SetTabHdrVal _sequence[1], "SeqParm", "DataNaming", 0
but couldn't find any objects or tables referring to the "Sample Info" dialog box when running in single sample mode.
I can bring the dialog up with EdSampleInfo but sending keystrokes seems to be a different story...
