Exporting data from ChromQuest to Excel
I have been trying to export data (peak retention times, areas, efficiencies, etc) from ChromQuest (version 4.2.34) to Excel, with not much success.
From the 'Avanced Method Option' I selected the 'Export enabled' box; from the drop-down menu I selected 'peaks' and I selected the parameters to export (RT, Area, As, N).
In the 'export option', the 'field separator' I selected was 'tab', and then provided the path for exporting the data to.
What I am getting is a list of data points (I suspect the actual peaks data points), but not the parameters that I need.
Would anybody be able to help me on this? I have hundreds of chromatograms to process and at the moment I am manually writing down the values and then inputting them in my Excel spreadsheets.
Many thanks
Monica
In our older ChromQuest 2.51 it was
Sequence->Summary, then select the data for output, type the filename using the button and set the field separator to TAB.
Final Reprocess the sequence (Sequence->Process) and the new datafile should be made.
In total there are 40 users online :: 0 registered, 0 hidden and 40 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 40 guests
