Antioxidant activities
Posted: Wed Jan 12, 2011 2:12 pm
Dear people,
I am trying to dissolve my plant extracts which are extracted from 6 different polarity solvents (water, ethanol, methanol, acetone, ethyl acetate and hexane) with methanol in order to proceed with antioxidant activities assays. However, plant extracts of water, acetone, ethyl acetate and hexane could not dissolve with methanol. I had tried to sonicate them but unsuccessful to dissolve.
I was told two ways of solution. First, dissolve with its initial solvents. Eg. Hexane extract dissolve with hexane solvent instead of methanol. Second, dissolve with additional of DMSO.
Is there any ways to make it possible to dissolve in methanol? How to compare if the extract are dissolve in different solvents? If use DMSO, what is the recommended amount to add in?
Thanks and appreciate!
