Problem with HPLC - one line has no pressure
Posted: Wed Feb 23, 2005 9:18 pm
After changing one of the reservoirs for my Alliance 2695, I discovered that the system won't prime (either wet or dry) on the line for which I just changed the bottle. Talked to tech support who said that if there's no pressure on any of the lines, it's a check-valve problem. But however, the system will prime on all other lines. I am kind of new to troubleshooting, but imagine that a clear place to start would be to check a filter or input line.
Any advice? Thanks for your time,
Dave
Dave
