Problems with turbomolecular pump
Posted: Fri Jan 07, 2011 3:40 pm
Dear all,
I'm working with a GC-MS that has not been used for the past 8 years. It is an Agilent 6890-5973N. I was able to put it online and it seemed to work fine until we had a power shortage last week end. When I came in the vacuum sideplate was open, the foreline pump was on. I guess also the turbo pump was on (at low speed), but I'm not sure of that.
My problem now is that when I pump down the turbo pump reaches 100% as usual, but after 22 min it starts to decelerate slowly but constantly (when it reached 85% I vented). I have a Edwards Standard Turbo pump. The controller have 4 lights, 1 green and 3 red. I noticed now that the 3 red are on and the green one is off. I don't know how they were when the machine was working before the power shortage.
Do you know what those lights mean? do you have any suggestions to fix the problem before I decide to buy a new turbo pump? is it possible that the turbo pump is fine and only the controller is to be replaced?
Thanks in advance for your help
Francesca
University of New Hampshire, USA
Francesca
