Effects of moisture on a GC-FID
Posted: Tue Jan 04, 2011 7:42 pm
Hello! This is my first post on the Chromatography Forum!
I have been running a 1 in 40 Propylene Glycol deicer to Acetone on our GC-FID and getting a strange flat topped plateau. It was recently discovered that the PG is 8% water. I was wondering if our inability to resolve the peak was due to the moisture? We are running a 30m Rtx-1 fused silica column with an id of 0.32 mm.
Thank you.
Thank you.
