LC-qqqMS and Metabolites
Posted: Sat Jan 01, 2011 4:32 am
I'm trying to implement a project to measure intracellular metabolites of bacteria using a Agilent LC Triple Quad MS. The metabolites of question are: ATP, G6P, NAD, F6P and Pyr. However, the main focus of the project is phosphorylated metabolites like DMAPP and IPP.
I'm trying to get the MS work done by going straight to the MS in ESI- however, as of now it's not going well (I think my mobile phase is incorrect). (10 mM Tributylamine solution at roughly pH 4.5):(methanol)
However, my main question is what type of column is preferable in my situation? I initially setup my project using tributylamine in my mobile phase with the idea that a RP column will be used. I found that TBA lingers in ESI+ mode and because the machine I'm on is shared (eg: not owned by my department) this is suboptimal.
I'm currently thinking about HILIC or PGC columns (with HILIC being the possible favorite).
TL;DR - Undergrad student needs help selecting column/mobile phase setup for phosphorylated metabolites on an LC-qqqMS.
PS - I do have a stack of journal articles to get through however, I'm still searching for a good resource for the fragmentation and collision methodology applicable to my situation (voltages and the such).
Thank you in advance.
