Minimu resolution in HPLC
Posted: Sun Feb 20, 2005 12:00 am
I am developing a method to separate an API and 10 related impurities. The resolution is higher than 2.0 for all pairs except for one pair of impurities, which both elute right after API and the resolution is about 1.0~1.2. I tried to improve the resolution of this critical pair. However, I can only do so by sacrificing the resolution of API and the impurity right after it, which is not a favorable choice.
I read from a textbook that the resolution can be relaxed to ~1.0 if the components to be separated are more than 10. However, my method is intended to be used for a drug product. Is the above rule still applicable?Is there any official guidelines on this topic from oranizations such as ICH, FDA or USP?
Thank you in advance for your help!
