Agilent 1260 Leak Help!
Posted: Tue Dec 28, 2010 10:41 pm
First, as I said before, while I have a lot of HPLC experience, it was all on Water's equipment and I am unfamiliar with Agilent HPLC equipment and trying to figure things out as I go along, so all suggestions are welcome
Awhile back I was having a problem getting a baseline on the RI detector on the system. It seemed to go away when I tightened up the pre-column holder... Then I did not use the system for about a week. Last Thursday when I started it up again, the RI was drifting downward very significantly with a steep slope even after equilibrating for several hours... I noticed a leak at the pre-column inlet (though the TCC was not detecting a leak) and thought maybe that was the problem.
So figuring that the ferrule was not seating right, I changed the line from the heat exchnager to pre-column using new nuts and ferrules.
Now I keep getting leak errors from the TCC module, but for the life of me I can't see any leaks visually at it or using the kimwipe test on all the fittings in the flow path.
I really need to get this up and running ASAP, so I would greatly appreciate suggestions.
- Karen
- Karen
