Chemstation: Report Creation During Reprocessing
Posted: Tue Dec 21, 2010 8:22 pm
by Karen01
As I said I'm trying to learn ChemStation and have B.04.02 and B.04.03 in the lab ( can I, and is it legal to use the .03 disk I jut got for a new system to update 0.02 software that came with an HPLP installed in October? I really want to keep both systems on the same version to make my life simpler!!!)
I created a custom report that I want to use to automatically generate reports to file (PDF and text) while running or reprocessing a sequence. Since I've created the report I've not run any new sequences so have been play with reprocessing in the offline version. Setting the Sequence output to use Sequence setting or setting the same things is specify report and then reprocessing does not produce the files...
What am I missing? I have to believe the software is capable of doing this!
