Injector Problems on HP 5890 GC using ChemStation
Posted: Wed Feb 16, 2005 5:10 pm
I am doing ethanol analysis from about 0.5 to 15 % in water. The column is a DB-5, 0.25mm x 30 M x 0.25 um film thickness. All flows have been checked and injector/FID detector has been cleaned, with new septum, glass insert (split/splitless with cup, no packing) and 0-ring.
I have done manual injections for external calibration with great peak shape and a corr. coefficient of 0.9993. When I attempt to use the autosampler on fast plunger speed, i get a series of sharp peaks on a hump. When I use slow injection speed I get a large tailing peak about 1.5 minutes long. I have cleaned the rinse/waste vials and can use the autoinjector syringe manually and get excellent results.
does anyone have any suggestions? I need to use the autosampler, as I have many samples.
Ricardo
Ricardo
