Running api 3000 with sealed orifice
Posted: Sun Dec 19, 2010 4:43 pm
Currently we use tanked nitrogen to supply the sciex api 3000.
The instrument is only used from time to time, so to save gas we turn it off between uses. When we start it up, we seal the orifice with a bit of Teflon tape and we do a soft-start. When doing a soft start the curtain gas is left off. This saves us gas while the turbo pump spins up which can take a couple of hours.
I was wondering what the effect would be if the instrument were left running like this for an extended period, say over a weekend.
With the orifice sealed, would the vacuum generated eventually be enough to draw in oil vapours from the roughing pump?
Has anyone done this or know of any problems that have occurred because of it?
Alp
Alp
