Does anyone out there know the source of the error below?
"Limit Switch Not Found
Motor Aux 1
Reference Fault
Exception 140"
The full story is that some headspace vials cracked in a couple of agitators overnight and of course the water and salt flowed to parts that water and salt shouldn't be. I've repaired one by dismantling and removing all the salt. The other is coming up with the error above. Normally the agitators are returned to our service provider for repair (and will be in this case if I can't get it working). However, this being Friday we need the instrument up and running for the weekend.
The usual sources of info, internet, manuals, etc are coming up with nothing. I get the impression that Gerstal doesn't like releasing too much info on error codes.
As always, any advice appreciated.
Regards
Rich
