Shimadzu column oven leak sensor
Posted: Tue Dec 07, 2010 7:25 pm
by lena
I recently started working with a Shimadzu CTO 10-AC column oven but do not have the manual for it. It is showing an error "err lk.s" which I suspect is the leak sensor being open. Does anyone know where the leak sensor is located on this model and how it can be closed/fixed?
Thanks in advance.
Re: Shimadzu column oven leak sensor
Posted: Thu Dec 09, 2010 9:20 pm
by Holledijk
It is just in front of the FAN and it reacts on vapour pressure. You can replace it but the new sensor needs to be calibrated again in some way. The best is to do this after contacting your local Shimadzu dealer.
Posted: Wed Dec 15, 2010 8:33 pm
by lena
Thank you Holledijk, apologies for my delayed response. I have contacted Shimadzu in the meantime and a new sensor is on its way.
Thanks again!
