Multi-level Calibration in ChemStation
Posted: Sat Dec 04, 2010 4:45 am
As I've mentioned, I'm trying to learn/use ChemStation coming from Empower.
My latest challenge is multi-level calibration Curves... In Empower I create an Integration method with the compounds names and retention times, Curve type, fit , weightings etc and if I want to average by level.
In the sample set I enter that it's a standard and the standard amounts for as many analytes as I want, and if I care, level IDs...
I enter the analytes and their amounts in a single 'spreadsheet' all at once which is very easy/fast.
In Empower levels are used to optionally average replicate standards for each amount, not necessarily ID different amounts and don't HAVE to be used. If you don't enter them and specify Average By Level then each sample/Amount pair is an independent data point for the regression.
At the end of the run, if I made any errors is setting up the Sample Set, I can change Unknowns to Standards Or QC's etc. and enter the amounts. In fact sometime in a hurry to get the run started I don't enter amounts (when using new standards solutions) until after the run. As i don't make new standard solutions for every run I use a Sample Set to make a Sample Set Template with so I don't have to reenter amounts (which vary a little because of weighing)
To do the calibration (among other ways) I can just process the sample set (or pick, the individual Channel data from a table/spreadsheet that has all data for all channels with sample name, date acquired, Sample Set name etc, which I can filter on any column as a batch) and it creates separate calibrations curves for each analyte ... I don't have to even look at the chromatography (though I can do it that way if i want) or load individual 'levels' from a sample set to do the calibration...
Then as long as I don't do another calibration with that integration method, I can keep processing samples with that integration method and it will keep using that set of calibration curves to calculate unknown amounts.
The whole process is quick and easy...
I did a run on Chemstation with 6 different standard concentrations, with 3 analytes in the standards (all analytes are not at the same concentration in the same standard solution).
First, because of a mistake setting up the sequence, I need to change one of the vials that was run from a Sample to a Standard... I can't seem to find a way to do it... i it possible? If so how?
Looking at the Agilent documentation, doing multilevel calibration in ChemStation looks amazing cumbersome and time consuming in comparison to Empower... and it's also not obvious how to simultaneously do multiple analytes as independ and calibration curves at the same time. I have to load individual signal to Calibrate? Can I do all 3 analytes at once, or do I have to go through that 3 times?
It's can't be that slow/cumbersome ... am I misunderstanding things?
- Karen
- Karen
