RI Basline issues
Posted: Thu Dec 02, 2010 4:31 pm
I'm having significant RI baseline issues. I'm not used to this specific detector, mobile phase or column or HPLC so I am not sure if it's detector issue or if it's due to some other issue or if it's "normal" (which i doubt. It's been a long while since I had dome much with an RI... and way back when it was GPC work not Carbohydrate quantiation.
I'm using an Infinity 1260 with a binary pump and the 1260 RID
My mobile phase is ACN/Water 80:20 (premixed). The column is a 150 mm Agilent Carbohydrate column. Both the RI and column are are to 38C. Because of the noise level I'm getting HORRID sensitivity. The noise looks to be about 1000+ nRIU from peal to peak!
I would appreciate any suggestions!
Thanks!
Here is What I am seeing:
Thanks!
