Volatile Fatty Acid Analysis
Posted: Mon Nov 29, 2010 11:50 am
Hi all,
I'm having a bit of trouble deciding which HPLC column to use for my research.
I will be running a fermentation experiment and want to analyse supernatants for the presence of acetic, propionic and butyric acid. The mobile fase will be H2SO4, and for a detector I am planning to use UV. I have been looking at the Bio-Rad Aminex HPX-87H and the Phenomenex Rezex ROA. The problem is this: I can find a lot of comparable research that uses the Aminex column, and none that described using the Rezex. However, seeing as that the Rezex is about £600 cheaper and I am on a very tight budget, it would be very nice if I could go for that one.
Can you guys give me any leads on which would be a good choice, and, in case it is the Rezex, perhaps one or two references to literature (my supervisor will need refs before I can even mention using the Rezex...)
Thanks a lot in advance!!
Nieky
Nieky
