Perkin Elmer TurboMatrix ATD650 Recollection problem
Posted: Wed Nov 24, 2010 12:37 am
Im new to posting here but have found this site to contain some very valuable information and I would like to begin by saying thanks all the effort put in here. You have made my life a bit easier by existing. Thx!
now i am coming to ya'll for some help.
I am having some trouble with a Perkin Elmer Turbomatix ATD 650. My lab purchased one earlier this year. We are using it to run TO-17. Connected to it is a 6890 and 5973n.
column is a rxi 5ms .28x 1µ film x 45meter
1 ml/min col flw
If you are familiar with the Atd650, the instrument has a function to recollect a portion of the sample back on to the desorbed TD tube or to a fresh one. We are specifically interested in using the same tube for recollection. I am writing to see if anyone else has experienced the same phenomena that we are. Basically the ATD is not spiting the sample at the ratio for which it has been set. For example, we have the instrument set to recollect 90% of the sample while 10% is sent down the column. In actuality it is closer to a 3:1 ratio, and while the ratio is incorrect, it is consistent. We have determined this through empirical data and fortunately have been able to run the instrument on a production basis with this knowledge. I would like to solve the puzzle though. I am working with PE right now to solve, but i wanted to ask here as well.
Has anyone experienced this? I am happy to provide more detailed system specs if needed.
mike
1 ml/min col flw
mike
