Comparing IT-ToF with QToF
Posted: Wed Nov 17, 2010 3:20 pm
I am trying to get some details on the advantage of using IT-ToF for metabolite analysis of low mass range (180-500). The matrix contain lower proportion of these LMW compounds and as I was searching through the literature it seems that IT-ToF offers better sensitivity to lower mass ions.
It is claimed that, the IT-ToF achieves this by changing the period of voltage pulses during the ion introduction into ToF. And based on the ion distribution this can be controlled to get higher sensitivities in all mass ranges.
Since I haven't used it IT-ToF at all, and I have very limited experience with QToF, I will greatly appreciate any help in deciding which instrument to go with. Also can a chromatographic separation prior to sample introduction give better sensitivity of low mass range in either of these detectors?
