Leaking in PAD cell on Dionex system
Posted: Tue Feb 08, 2005 4:09 pm
This applies to those familiar with the Dionex PAD detector. Please forward to anyone that might be able to contribute to the information requested.
We are presently in need of troubleshooting advice. Recently, we have noticed a leak in the PAD cell of our BioLC system. The leaking occurs between the gold electrode block and the cell body (where the pH reference electrode is in place). More specifically, we have observed the formation of salt crystals on the side of the cell body, on the two wing nuts and between the cell body and the gold electrode block (around the gasket). With a 100 mM NaOH eluent, pressure is around 900 psi at a flow rate of 1 ml/min using a PA1 column (“250 x 4.6 mmâ€
