Separation of Acyl halides with HPLC
Posted: Sat Oct 30, 2010 5:43 pm
Hey guys! I'm an undergrad doing research at Clemson. I'm trying to separate 2 almost structurally similar compounds (2-bromoisobutyryl bromide and 1-bromocarbonyl-1-methylethyl acetate) using a fast acid column but the 2 peaks co-elute at about 2.8 mins. My mobile phase is a 5mM sulfuric acid in HPLC water at a flow rate of .5mL/min and my column temperature in 40 C....Is there something different I can do or try?? Please let me know!
I could not attach the link for the structures of the 2 compounds(2-bromoisobutyryl bromide and 1-bromocarbonyl-1-methylethyl acetate) but they can found on the sigma-aldrich's website: http://www.sigmaaldrich.com/european-export.html
Thanks very much!
Thanks very much!
