please help me
Posted: Fri Oct 29, 2010 12:33 am
Hi everyone,
I had a bad day today in our GC/MS lab. I was trying to fix a leak indicated by my routine water/air check. I thought it was the column that goes into the transfer line was not tightened... Then, I still do not know what I was thinking about, but I was stupid enough that I unscrewed the source nut and then I heard the noise of the foreline pump and saw some fume-like thing off the foreline pump and I then realized that i did not vent the MS!!! The foreline pressure went off the ceiling of course. I immediately turned off the foreline pump and did a "vent", waited for the diffusion pump to cool down and turned the whole system off.
I tightened everything, and restarted whole system. After 4hr waiting, I tried an autotune, the error was that like "signal too low to do an autotune ". I am wondering if the foreline pump is bad because the foreline pressure was showing "160 mTorr (pressure Ok)". I think normally it is shown below 50 mTorr. Or maybe the MS is bad due to my stupidity?
Can anyone here help me analyze this problem now? Please help !!! :lol:
Thanks a lot!
Emma :)
Thanks a lot!
Emma :)
