Plasma extraction
Posted: Tue Oct 26, 2010 1:10 am
Hi
Im currently performing an LCMS for chloroquine and quinine in plasma. My peaks in standard solution has come out quite nicely on the lcmsms.
however after extraction from plasma only the internal standard can be identified. chloroquine and quinine has disappeared.
my plasma extraction involves adding 200ul of spiked plasma and 400ul of IS in methanol. this is then added with a buffer solution of ammformate:methanol ph4.
ive tried extracting the chlroquine and quinine with ACN but the peaks cant be detected.
i was hoping to get some advise on this. Thanks!!
