"Melissa leaf was ground to a fine powder (400) and 1.000 g of the powdered drug
was refluxed with 50 ml of methanol in a Soxhlet extractor for 3 h and evaporated to
dryness. The residue was dissolved in methanol, filtered and diluted to 25.0 ml with
methanol prior to analysis (solution A).
For sample pre-separation, 0.1 ml of solution A was diluted with 0.4 ml of methanol
in an Eppendorf tube and 0.2 ml of tetrachloromethane was added to give a clear solution.
Adding further 0.3 ml of distilled water to the solution causes the formation of a
two-phase system. The tube was shaken, and centrifugation (10 000 rpm, 10 min) was
used to obtain a sharp interface. The upper, water-methanolic layer was separated and
injected into the HPLC system."
from, "ROSMARINIC ACID – AN IMPORTANT PHENOLIC ACTIVE
COMPOUND OF LEMON BALM (MELISSA OFFICINALIS)"
1Tóth, J. – 1Mrlianová, M. – 1Teklovia, D., et.al.
_____________________________________________________________
see:
http://www.fpharm.uniba.sk/Dokumenty/Ac ... A1%20M.pdf
