Gas flow rates for GC/FID on a 5890
Posted: Sun Oct 17, 2010 8:58 pm
Hi all -
I have a question regarding setting flow rates on a 5890 GC/FID. I am attempting to use the following flow rates:
He column flow: 7 mL/min
He make-up: 20 mL/min
Hydrogen: 30 mL/min
Air: 400 mL/min
I am using an Agilent electronic flow meter (Veriflow 500), which can be set to the gas that is flowing at the time. I've noticed that if I set the flow meter to meter Helium flow it will read around 460 mL/min when all three gases are flowing. When I set the flow meter to Air, it reads around 70 mL/min with all gases flowing.
It seems surprising that the meter would show such different readings when the meter is toggled between Air and He settings. Does anyone know if this sounds normal?
Does anyone have a good procedure for setting flows using a meter like this one?
Thanks!
Hydrogen: 30 mL/min
Air: 400 mL/min
Thanks!
