Help-high ECD background value
Posted: Thu Oct 14, 2010 3:32 am
Hi folks,
I'm an environmental engineering grad student and working on the haloacetic acid analysis using Agilent 6890 micro-ECD system. I recently encountered a weird problem with the ECD background value. When I load up the Idle method, the signal output typically reaches 844XXX (yes, that's a crazy number); however, the background signal is fine (~800, normal value) when I run my HAA method. I cleaned the inlet system and re-tighten the column connection, but it doesn't seem to help...
I'm not sure why this happens, but I guess there is an oxygen leakage somewhere
. Has anyone seen a similar problem before? Any comments/suggestions would be much appreciated!
Teng
Teng
